penseroso
Jun 12, 2019Aspirant
Orbi not loading some sites or downloading Apple updates (404 message) Mac OS and iOS
Orbi RBR53, used with a Orange LiveBox 4 DSL in France. When I load some occasional pages (such as Neatgear) to ‘open’ sites (such as the local cinema) I am directed to a login. In other words, I c...
- Jun 19, 2019
Very many thanks for your help, Furrye38 and richin-rich. Problem resolved - although in fact it was an IP conflict sorted out on the telephone with Netgear technical support. Very grateful for your support.
Jun 14, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- penserosoJun 15, 2019Aspirant
Thank you, FURRYe38. I probably should have marked this post solved, although it isn't. The issue seems well covered elsewhere. My problem is having difficulty logging in to Netgear Support because the 'load' problem extended to Netgear as well as other sites. I am now negotiating with Technical Assist to try and resolve this but I think the problem should be resolved by changing from Router to AP mode. But I really appreciate your full reply and I apologise if I have wasted your time.
- FURRYe38Jun 15, 2019Guru - Experienced User
Sounds like the issue may have been that your ISP modem already had a built in router and wifi.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease mark your post as solved so others will know.
Enjoy. :smileywink:
