penseroso
Jun 12, 2019Aspirant
Orbi not loading some sites or downloading Apple updates (404 message) Mac OS and iOS
Orbi RBR53, used with a Orange LiveBox 4 DSL in France. When I load some occasional pages (such as Neatgear) to ‘open’ sites (such as the local cinema) I am directed to a login. In other words, I c...
- Jun 19, 2019
Very many thanks for your help, Furrye38 and richin-rich. Problem resolved - although in fact it was an IP conflict sorted out on the telephone with Netgear technical support. Very grateful for your support.
penseroso
Jun 15, 2019Aspirant
Thank you both for your advice and suggestions. The problem is that I cannot login to orbilogin.com – it won’t accept the admin/password. After a couple of tries it defaults to asking for the serial number. This doesn’t work either. The result is that I am unable to make the change-over from Router to AP. Is the problem perhaps to do with my internet modem (Orange Livebox in France) even though I have turned off WiFi. Any thoughts would be greatly appreciated.
Jun 16, 2019Guru - Experienced User
Try a factory reset on the RBR with wired PC connected to the RBR and walk thru the setup wizard. Setup a new password and write all important information down. Once the setup wizard is complete, you should be able to access the advanced tab/advanced settings/router and AP mode menu. Set up AP mode there.
Review the 3 suggestions about your ISP modem.
What is the model # of the ISP modem?
- penserosoJun 16, 2019Aspirant
Thank you very much, Furrye38. I am very grateful for all your suggestions. I am on a business trip now until the middle of the week but will try this out as soon as I get back. I will report back to you then.
- FURRYe38Jun 18, 2019Guru - Experienced User
:smileywink:
penseroso wrote:Thank you very much, Furrye38. I am very grateful for all your suggestions. I am on a business trip now until the middle of the week but will try this out as soon as I get back. I will report back to you then.
- penserosoJun 19, 2019Aspirant
