CrimpOn's avatar
CrimpOn
Orbi not logging activity as specified
Since the firmware update to 2.2.1.210, my Orbi seems to log ONLY DHCP assignments, admin logins, when it sends a log file, and time synchronization.  It NO LONGER logs known DOS attacks and port scans.  The box is clearly checked.  I have attempted to "fool" the Orbi by clearing all the check boxes, "applying", then checking the boxes and "applying" again.  No change.  I searched for "log" in the community forum and found nothing relating to this.
Is this a known issue?
Is there a fix?
Thanks
  • FURRYe38's avatar
    Try manually loading FW and resetting factory defaults and set up from scratch. See if the logs gather what your looking for...
    • CrimpOn's avatar
      CrimpOn
      I understand that when "turn the damn thing off and back on again" doesn't work, the ultimate solution is to "reinstall everything from scratch."
      I still would like to know "am I the ONLY person whose Orbi does not log intrusion attempts as it did before the firmware update?"
      • FURRYe38's avatar
        Seems to be unless nobody else is using this feature at the moment...
