6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
Mstrbig
Aug 06, 2020Master
Set that same IP address as static on the PC itself.
6old3nra1n
Aug 06, 2020Tutor
Why would setting a static IP on the PC itself be necessary? Should the IP assignment that's router-based be enough? As in, the assignment comes from the router only, no other place. So when the IP changes to a different IP, that's based on what the router did, not any other device or source. The PC certainly didn't change the IP itself.
I don't think this feature is working properly on the router. I've had dozens of routers beforehand and all of them handled static IP assignments correctly WITHOUT having to assign a static IP on the computer/laptop itself.
