6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
dunciad
Nov 21, 2020Guide
This DHCP is rubbish.
The IP address reservations do not work. There is no stability (ie if a device had an IP address, and it was not resused elsewhere, then the device might not get the same IP address). If you edit the list of reservations you see that the list of existing reservations in the edit window differs from the list you see when you just click on the information page. What a complete p.o.s.
Nov 21, 2020Guru - Experienced User
Then find something else that works for you or install a different router and use the Orbi in AP mode.
Haven't seen any DHCP issues when in router mode on mine. v16.
