6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
dunciad
Nov 21, 2020Guide
Sure I could find something else that works. But I paid for something that should already work. If Netgear will refund my purchase then I'll gladly return their hw/sw.
It works for you. Bravo. It doesn't work for me. Nor for many others according to this post.
Nov 21, 2020Guru - Experienced User
If your unit is newly bought, then return it.
It not, maybe post more details about your system and maybe we can help figure yoru problem out.
