6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
6old3nra1n
Aug 07, 2020Tutor
So you guys won't believe this -- I decided to change the range of the DHCP-assigned LAN IP addresses from [192.168.1.2 to 192.168.1.254] to [192.168.1.2 to 192.168.1.100].
In my previous address reservation attempts, I set the reserved IP to 192.168.1.25 ...26, 27, etc. Then I set it to something really far out within the IP range, namely 192.168.1.100. Still within the original range, and still within the new range.
So technically nothing should change, right? But wait, there's more! When I changed the range, clearly the router did "something" and reset all connections. I noticed that even my router page was no longer accessible (for the time being). So when I simply typed "ipconfig" (without releasing or renewing anything) into my PC, it showed 192.168.1.100!
It's almost as if changing the DHCP-assigned IP range caused the system to start from scratch (perhaps the DHCP table itself got rebuilt) and therefore assigned my PC the correct reserved IP address of 192.168.1.100.
The question now is -- if I change the address reservation to another IP or if I reserve another IP for another device, will it work? Or will I have to "reset" the DHCP by changing the IP range again... I'm scared to try.. haha..
jemenake
Nov 11, 2021Aspirant
Using 6old3nra1n's solution worked for me. I reduced the size of the dynamic DHCP pool to not include the IP's that I was statically assigning to individual devices. Like they experienced, I also observed the router seeming to reboot. So, my guess is that one of two things is happening:
- The DHCP daemon in the router ignores any static IP assignment which falls within the dynamic pool, or
- Changes to the DHCP configuration require that the DHCP daemon be restarted, and the web UI fails to do this when you just add static assignments, but it does do it when you change the dynamic IP range.
I guess the way to test this would be to either:
- Change the dynamic IP range back to include the static assignments and reboot some of those statically-assigned devices. (if the devices lose their static IP's, then we have case #1 from above. If they don't, we have case #2)
- Add a new static assignment outside of the dynamic range (if it works, then we have case #1 from above. If it doesn't, then we have case #2).
- FURRYe38Nov 11, 2021Guru - Experienced User
Lets remember that for "Static" IP addresses, these are configured and placed ON devcies themselves. So if static IP addressed devcies are being used and connected, then these static IP addressses need to be outside of the default DCHP IP address pool. For NG routers, NG defaults to max pool size, so users need to reduce the pool size to allow for static IP addresses to be used OUTSIDE of the IP address pool.
For IP Address "Revervations", these are set ON the Router for devices and these are always with in the DHCP IP address pool.
- jemenakeNov 11, 2021Aspirant
Let's remember that the word "static" just means "not changing". Whether an IP is not changing because it is configured at the host or because the IP is reserverd for a specific MAC at the DHCP server, it would still be a "static IP". However, that leads to confusion, so I've tried to avoid that phraseology. In my post, I tried to be carefull to use the phrase "statically assigned" to refer to IP reservations on the DHCP server. If there's an accepted standard terminology to discriminate between those two, I'd love to hear it.
- CrimpOnNov 11, 2021Guru - Experienced User
Cisco uses the term static DHCP.
I also see DHCP reservation used by vendors.
Your term of statically assigned seems equally fine.
I agree with FURRYe38 that static IP without any qualifier generally implies "set on the device itself".
It's not clear to me if the "problem is solved" and the discussion has moved on to semantics, or.....
