6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
SdeGat
Mar 14, 2022Apprentice
Thanks for the insight CrimpOn. You know I don’t mind the rant. 🙂
BTW, where did the “quote” function go? 💁♂️
CrimpOn
Mar 14, 2022Guru - Experienced User
The Quote button has been replaced by that ginormous double quote mark on the menu bar. and the other options only show up if you click those three dots (...) and there appears to be no way to "go back" (sigh)
- SdeGatMar 14, 2022Apprentice
Thanks again CrimpOn. That’s not coming up on my iPad. ☹️
And I cannot show you because there’s no insert image either! 😫EDIT: I e-mailed the ipad screen dump to my desktop:
- CrimpOnMar 14, 2022Guru - Experienced User
Gott in Himmel!! Was ist los?
My Windows browser shows this menu bar:
And clicking on the three dots changes it into:
and that Browse button in the lower left now looks like this:
Maybe Safari is "different"? Maybe the browser cache needs to be cleared?
