6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
SdeGat
Mar 14, 2022Apprentice
Thanks again CrimpOn. That’s not coming up on my iPad. ☹️
And I cannot show you because there’s no insert image either! 😫
EDIT: I e-mailed the ipad screen dump to my desktop:
CrimpOn
Mar 14, 2022Guru - Experienced User
Gott in Himmel!! Was ist los?
My Windows browser shows this menu bar:
And clicking on the three dots changes it into:
and that Browse button in the lower left now looks like this:
Maybe Safari is "different"? Maybe the browser cache needs to be cleared?
