6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
CrimpOn
Mar 14, 2022Guru - Experienced User
SdeGat wrote:
CrimpOn isn’t it a good (easier) practice to have a range of addresses that the router will not use/assign?
Or are the Orbi routers more intelligent and automatically recognize fixed addresses in devices and leaves them alone?
It is uncommon in a forum post to see "Orbi" and "intelligent" in the same sentence. There are constant complaints about the way the router fails to honor assigned IP's. I personally struggle when I get a new device and know what IP I want it to have but the manufacturer has failed to put the MAC address anywhere on the product or the packaging. Once it gets connected, the *&*%^* Orbi allows it to keep that first IP even though I have created an entry in the IP assignment table and then powered the device off and back on. My practice with these devices is to connect it to a junk WiFi router that I keep sitting around, just so I can learn the MAC address before connecting it to the Orbi.
(enough Rant. sorry)
In general, the accepted practice is as you described. Set aside a set of IPs for device assignments and a separate set of IPs for the DHCP pool. With 250 IPs to choose from, there is no fear of "running out" of either. For example, 2-100 for assignments and 101-250 for DHCP is a common practice.
SdeGat
Mar 14, 2022Apprentice
CrimpOn wrote:In general, the accepted practice is as you described. Set aside a set of IPs for device assignments and a separate set of IPs for the DHCP pool. With 250 IPs to choose from, there is no fear of "running out" of either. For example, 2-100 for assignments and 101-250 for DHCP is a common practice.
Going back to this, it looks like the RBR50 does not support the setting up of a range, does it?
- CrimpOnMar 14, 2022Guru - Experienced UserOn the web interface, LAN setup menu
- SdeGatMar 15, 2022Apprentice
CrimpOn wrote:
On the web interface, LAN setup menuYes, of course. Thanks CrimpOn.
I think I'm getting old. :-(
192.168.1.0 to .100 is reserved so that I can assign addresses from devices without issues.
- CrimpOnMar 15, 2022Guru - Experienced User
Well.... actually 0 doesn't exist and 192.168.1.1 is taken already by the router, leaving 2 - 100. Still plenty of IPs to use.
Static routes are an entirely different concept than assigned IP's.
