6old3nra1n
Aug 06, 2020Tutor
ORBI not properly associating static IP
Hello! I've been trying to use the Address Reservation feature under Advanced -> Setup -> LAN Setup. I have a PC that is hardwired (Ethernet, not wireless) to the RBS50 satellite (not the base RB...
- May 04, 2022
I know this is an old thread but I was having the same problem with reserved addresses not getting assigned. I tried the "trick" of changing the DHCP addresses from x.x.x.21 to x.x.x.254 TO x.x.x.21 to x.x.x.100.
Restarted the devices that were not getting the addresses I wanted and it all worked. I had tried restarting the devices prior to changing the auto assigned addresses range and it did not work at that time. Only after changing the range of the auto addresses.
I know enough to know that should not change the addresses I wanted reserved. Nothing was assigned in the >100 range in the first place. All I know is it solved my problem.
CrimpOn
Mar 15, 2022Guru - Experienced User
On the web interface, LAN setup menu
SdeGat
Mar 15, 2022Apprentice
Yes, of course. Thanks CrimpOn.
I think I'm getting old. :-(
192.168.1.0 to .100 is reserved so that I can assign addresses from devices without issues.
- CrimpOnMar 15, 2022Guru - Experienced User
Well.... actually 0 doesn't exist and 192.168.1.1 is taken already by the router, leaving 2 - 100. Still plenty of IPs to use.
- SdeGatMar 16, 2022Apprentice
BTW CrimpOn, is it possible/desirable to have the satellites on static IP addresses?
- CrimpOnMar 16, 2022Guru - Experienced User
There is no method on the satellite to set it to a static IP address.
Like any other device, a satellite can have an IP set up in the IP Reservation Table on the LAN Setup page.
Being just a bit OCD, I like to "know where things are", so I have assigned almost every device connected to my network a specific IP address. (i.e. all the smart plugs begin at 192.168.1.41. All the cameras begin at 192.168.1.51, etc.) Nothing on the network actually cares, and I can already see that I did not leave nearly enough space for smart plugs. Oh, well. No one ever said being fussy was going to also be easy.
