Skrymir
Nov 01, 2016Guide
Orbi Not Responding
My Orbi was working fine this morning. Now I'm unable to access it. When. I restart the router the ring is solid white, then flashing white, goes off for a bit then comes on solid magenta and stays th...
peteytesting
Nov 01, 2016Hero
hi
so are you connected to the orbi sat or router
and are you connected by wifi or ethernet ?
connect by ethernet to the orbi and see if it picks up an ip address
if it does see if you can access the gui of the orbi
once you confirm that we can go further
pete
