Srobbie
May 03, 2019Aspirant
Orbi not seen on network
Hi setting up router app asks to go to WiFi settings and join Orbi - this doesn’t appear in my list
May 03, 2019Guru - Experienced User
Can you set up the orbi using a wired PC and web browser?
Srobbie
Hi my modem
B-FOCus 0-4G2PCM UK
I could hardwire into a pc ?
B-FOCus 0-4G2PCM UK
- FURRYe38May 03, 2019Guru - Experienced User
Yes. Connect up a wired PC or laptop to the back of the RBR and using a web broswer, navigate to orbilogin.com and walk thru the setup wizard.
Your ONT may have some routing abilities, This could be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopSet up the ONT and Orbi accordingly.
