biocoder
Apr 01, 2020Aspirant
Orbi not showing devices in AP mode
Orbi RBR50 firmware V2.5.1.8 not showing any devices in AP mode. I can see all the devices on the internet provider's router. It should have 2 satellites, many WiFI devices and network/ethernet c...
Apr 02, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
How is the RBR and RBS connected?
Are the RBS ethernet connected or wireless?
biocoder wrote:Orbi RBR50 firmware V2.5.1.8 not showing any devices in AP mode.
I can see all the devices on the internet provider's router. It should have 2 satellites, many WiFI devices and network/ethernet connected devices. I've logged into the Orbi local web app admin and it shows 0 satellites and 0 devices. The mobile app shows only 2 satellites but 0 attached devices. Yes, i've rebooted the Orbi after setting up in AP mode.
Thanks.
- AnonymousApr 02, 2020
factory reset is for lost password
- biocoderApr 02, 2020AspirantI forgot to mention that I did perform a factory reset because of this issue in an attempt to resolve it.
- FURRYe38Apr 02, 2020Guru - Experienced User
Is Daisy Chain enabled? Disable it if it is.
You can try downgrading FW to v30 or give Voxels FW a try:
biocoder wrote:
I forgot to mention that I did perform a factory reset because of this issue in an attempt to resolve it.- AnonymousApr 02, 2020
FURRYe38 wrote:You can try downgrading FW to v30 or give Voxels FW a try:
which do you think will be most effective?
