tNoorden
Oct 26, 2020Tutor
Orbi not visible for Nefit Easy - solution
There is another topic on this forum with a similar title but the presented solution did not work for me. It did find another solution that I wanted to share, but the original topic is closed and doe...
tNoorden
Oct 26, 2020Tutor
CrimpOn wrote:
tNoorden wrote:The workaround I found was to temporarily change the channel settings for the 2.4Ghz network. By default it is set to 'automatic'. When I set it to channel 10 the Nefit Easy was able to see the new WiFi network and it was able to connect. When after this I changed back the channel to 'automatic' the Nefit Easy's WiFi connection persisted.
Are you located in a country that allows 2.4G channels 12 & 13? The reason I ask is that some products are designed for the "US Market" that allows only channels 1-11 and if the WiFi channel is 12 or 13 the product will not detect it.
That could be yes. I am in the Netherlands. Nefit - the manufacturer of the thermostat - is a Dutch company origninally. I believe they have been bought by Bosch in 2004.
CrimpOn
Oct 26, 2020Guru - Experienced User
tNoorden wrote:
CrimpOn wrote:Are you located in a country that allows 2.4G channels 12 & 13? The reason I ask is that some products are designed for the "US Market" that allows only channels 1-11 and if the WiFi channel is 12 or 13 the product will not detect it.
Wikipedia indicates that Netherlands probably allows 12 & 13:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
One would think that a Dutch company would design products to recognize those channels. A simple test would be to manually select 12 or 13 and "see what happens". Or, if the thermostat suddenly goes off line, check which channel the Orbi 2.4G is on. With "auto" it will scan periodically and change channels if the algorithm decided a different channel is "better". This leads to a fascinating dance when a bunch of nearby WiFi networks are doing the same thing.
Or, I could be totally off on a tangent.
