sneh47
Aug 25, 2019Aspirant
Orbi not working, No Error/Warning lights
Hello I have had an Orbi system (RBR50 and a satellite) for a year and everything has been fine with the latest firmware. Yesterday I reset my router to see if my performance in a game was related t...
sneh47
Hi,
My modem is the 5268AC by Arris. I called ATT and put in bridge mode again so I could start testing again with all the possible WIFI channels and disabling the extra features such as daisy-chain and coexistence you suggested but it has the same behavior. I don't think these changes would help in my situation because I am testing on my PC which is connected to my router via Ethernet and still cannot get connection. For some reason Youtube still works fine on chrome yet nothing else will on the PC.
My orbi and satellite are about 45-50 feet apart like it has been for the past year. I have also only 1 wifi neighbor.
Very sad that I spent 350 on this setup and its not working after only a year. I tried calling netgear support but now they want me to purchase gearhead support because I dont have technical support anymore. I guess the Orbi is just bricked and can't route.
michaelkenward
Aug 26, 2019Guru - Experienced User
Guess you must have bust something in your earlier experimentation. Unfortunately, Netgear's support won't cover that so you are better off here. It is free.
It isn't obvious to me that your attempts at recovery have included the basic restart regime.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
sneh47 wrote:
...I am testing on my PC which is connected to my router via Ethernet and still cannot get connection.
So what happens on the PC? Any messages?
I'm afraid "cannot get connection" doesn't give us much to go on.
You can help by providing detailed descriptions of what you are doing, where it goes wrong and what messages you see.
- sneh47Aug 26, 2019Aspirant
Hi
Thanks for your guys' help. I'm sorry I cannot give a better description of my problems but basically everything looks fine on my PC(I have the PC ethernet icon on my bar) so I would assume its connected properly. However, I get the "This site cannot be reached" error page on any site I go to except Youtube for some reason(I assume that's is some cache issue).
However, my dad and I figured out that AP mode on the orbi and using the modem is working fine. We turned off the wifi radios on the modem like the earlier post suggested and that's where we are now. Everything is working fine now so I assume whatever components get used in the router mode that don't get used in AP mode are not working properly. I don't think I'm losing much from running it in AP mode since the ethernet backhaul is working fine still. I still have Daisy-chain Topology off from my previous testing but I'll try it on and see if everything still works.
Thank you guys for responding and helping me out I appreciate it.
- FURRYe38Aug 26, 2019Guru - Experienced User
Enjoy. :smileywink:
- michaelkenwardAug 27, 2019Guru - Experienced User
In AP mode, the Orbi does not use the router bit.
The symptoms you see are indicators that you may have a modem/router in front of your router. That the Arris delivers wifi sort of confirms this.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR SupportA lot of people use Orbi in AP mode – I do – often because they have better routers in front of it.
The Orbi loses a bit in AP mode, but not much. Don't tell your dad, but one lost feature is the ability to use Parental Controls on the Orbi.
sneh47 wrote:
Hi
One thing to check on the PC is how Windows sees the local network. When it first encounters a new network, it tries to protect you from nasties. So it decides ti label the network as a public network. It then blocks of things. To get your life back, you need to tell Windows it is a private network.
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
- sneh47Aug 27, 2019Aspirant
Hey Michael,
I think you are right. I talked with a different person on a different forum and they came to a similar conclusion. I was doing all this testing as if the arris modem was in bridge mode but I guess that was not the case. The ATT support person I called to put it in bridge mode did not seem like he knew what he was doing because I had to ask him a couple of times to do it. One thing I did encounter that I should've mentioned is that when I factory reset the Orbi it always started with a page saying the IP address has been changed to avoid conflicts. I think the setup link had something like "BRS WANLAN conflict.htm". So I guess I could call ATT support and fix the problem but we don't really need Disney, Armor, or the parental controls which my dad doesnt need for his 25 year old son :)
Thanks for the help again
