sneh47
Aug 25, 2019Aspirant
Orbi not working, No Error/Warning lights
Hello I have had an Orbi system (RBR50 and a satellite) for a year and everything has been fine with the latest firmware. Yesterday I reset my router to see if my performance in a game was related t...
michaelkenward
Aug 27, 2019Guru - Experienced User
sneh47 wrote:
so I assume whatever components get used in the router mode that don't get used in AP mode are not working properly. I don't think I'm losing much from running it in AP mode since the ethernet backhaul is working fine still. I still have Daisy-chain Topology off from my previous testing but I'll try it on and see if everything still works.
In AP mode, the Orbi does not use the router bit.
The symptoms you see are indicators that you may have a modem/router in front of your router. That the Arris delivers wifi sort of confirms this.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
A lot of people use Orbi in AP mode – I do – often because they have better routers in front of it.
The Orbi loses a bit in AP mode, but not much. Don't tell your dad, but one lost feature is the ability to use Parental Controls on the Orbi.
sneh47 wrote:
Hi
Thanks for your guys' help. I'm sorry I cannot give a better description of my problems but basically everything looks fine on my PC(I have the PC ethernet icon on my bar) so I would assume its connected properly. However, I get the "This site cannot be reached" error page on any site I go to except Youtube for some reason(I assume that's is some cache issue).
One thing to check on the PC is how Windows sees the local network. When it first encounters a new network, it tries to protect you from nasties. So it decides ti label the network as a public network. It then blocks of things. To get your life back, you need to tell Windows it is a private network.
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
sneh47
Aug 27, 2019Aspirant
Hey Michael,
I think you are right. I talked with a different person on a different forum and they came to a similar conclusion. I was doing all this testing as if the arris modem was in bridge mode but I guess that was not the case. The ATT support person I called to put it in bridge mode did not seem like he knew what he was doing because I had to ask him a couple of times to do it. One thing I did encounter that I should've mentioned is that when I factory reset the Orbi it always started with a page saying the IP address has been changed to avoid conflicts. I think the setup link had something like "BRS WANLAN conflict.htm". So I guess I could call ATT support and fix the problem but we don't really need Disney, Armor, or the parental controls which my dad doesnt need for his 25 year old son :)
Thanks for the help again
- michaelkenwardAug 28, 2019Guru - Experienced User
This is not something that I would expect them to do by remote control. Usually it is done at your end through the browser graphical user interface. In the same way that you set up the Orbi in wireless access point mode.
Search the web for "arris 5268ac bridge mode" and there is plenty of advice.
That is a sign that your Orbi is starting in router mode and has encountered another router on the network. So it has picked an address that does not clash with the other router.
As you have found, you can easily put the Orbi into AP mode. Apart from Parental Controls pretty well everything else will still work. Unless, that is, Netgear adds software widgets like "Armor" to protect you from nasties out there.
