flyershigh
Jun 25, 2018Follower
Orbi not working well withmy samsung tablets
My Orbi seems to work very well,Except on mt Samsung Galaxy Tab S3 and mt Galaxy tab E.Does anyone else have this issue?
Jun 26, 2018Guru - Experienced User
What FW are you currently using?
What channels are you using? Try using manual channels 1, 6 or 11.
What seucurity modes are you using? Try WPA and TPIK then try WPA2 and TPIK and AES.
Set up an IP address reservation ON the router for your devices.
Disable the following and see if it helps any: MIMO, Daisy Chain and Fast Roaming.
