MalcH
May 22, 2023Aspirant
Orbi not working with Apple devices
I have both Orbi RBR50 and brand new Ordi RBR760 (both with the latest updates) Both work perfectly with Windows 11 devices but will not work with Apple devices (all up to date). For example ...
- May 23, 2023
Hi all, thanks for all the suggestions, I have now resolved the issue.
What confused me was the fact that all the Apple devices worked initially then over a period of several hours they one by one lost access to the Internet.
The solution:
I accessed the router via the IP address locally and went into Advanced Settings, Control Access and discovered that Intent access was denied to all but my two Windows 11 devices even when the correct password was used to access the router WiFi.
I ticked the boss to allow additional devices to access the WiFi and instantly the issue was solved.
May 22, 2023Guru - Experienced User
Be sure that you disable WiFi Private IP Address feature on Apple phones and pads while at home:
Contact Apple support regarding there products.
