MalcH
May 22, 2023Aspirant
Orbi not working with Apple devices
I have both Orbi RBR50 and brand new Ordi RBR760 (both with the latest updates) Both work perfectly with Windows 11 devices but will not work with Apple devices (all up to date). For example ...
- May 23, 2023
Hi all, thanks for all the suggestions, I have now resolved the issue.
What confused me was the fact that all the Apple devices worked initially then over a period of several hours they one by one lost access to the Internet.
The solution:
I accessed the router via the IP address locally and went into Advanced Settings, Control Access and discovered that Intent access was denied to all but my two Windows 11 devices even when the correct password was used to access the router WiFi.
I ticked the boss to allow additional devices to access the WiFi and instantly the issue was solved.
michaelkenward
May 23, 2023Guru - Experienced User
MalcH wrote:
....but will not work with Apple devices (all up to date).
Have you considered that it might be the other way round?
Apple devices will not work with your Orbi?
Have you tried researching that side by talking to some Apple experts?
- MalcHMay 23, 2023Aspirant
The solution:
- FURRYe38May 23, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- MalcHMay 23, 2023Aspirant
Thanks, greatly appreciated.
I have now marked it as solved.
