hilllaguna's avatar
hilllaguna
Follower
Apr 09, 2017
orbi on MAC network won't find printer
INtalled a new Orbi wifi router to replace an Apple airport wifi system Connection to the Internet on al devices, in the house works fine, but itr will not find the printer which it is hardwired to. Searching shows it is a connected device wired, but when going to print something message says printer cannot be found.
1 Reply
    It's possible that the IP address of your printer changed when you changed over to Orbi.  Try deleting and reinstallig the printer on your Mac.
