Rnubes
Dec 09, 2022Aspirant
Orbi on NBN FTTP MS Teams Video not work
hi, I have Telstra NBN FTTP at 250/22Mg speed with Orib RBK50. For some reason, MS Teams on windows 11 using the native MS Teams client does not do video very well, it just does not work. I can see ...
michaelkenward
Dec 09, 2022Guru - Experienced User
For some reason, MS Teams on windows 11 using the native MS Teams client does not do video very well, it just does not work. I can see video but my video is blank.
I'm intrigued. What makes you think that your RBK50 is responsible for these problems?
I would look first at Microsoft. I do know that Teams is a bugger to get to play nicely.
I have two PCs on my desk. One happily uses the Teams client, the other won't work unless I use the browser interface.
I put this down to problems with one of my Windows (11) installations.
This is probably due to the Orbi sending lots of traffic to the NBN and the NBN policer dropping packets.
Can you explain what that means?
Is there something in the router's logs that leads you to this conclusion?
In many years watching this place, I have never come across a problem that is down to "sending lots of traffic" to anything.
But even if this is correct, don't you think that your first port of call should be whatever this "NBN policer" might be?
Of course, if anything is "sending lots of traffic" it would be the Team's client. The router just does what things tell it to do.
Appreciate some thoughts and for the netgear to fix this problem as I am sure other have it given we work from home now. Thanks!
Before Netgear can fix anything, it needs to be convinced that it is something that it can, and should, fix, rather than something else.
People have reported problems with Netgear routers and Teams but they don't seem to relate to the experience you describe. So it may take a lot more evidence to jerk the coders into action.
Search - NETGEAR Communities – teams
Perhaps you could review those messages – maybe you have done that already – and come back with some evidence to back up your interesting theory.
Rnubes
hi you are correct that it is not the orbi but teams that has the issue with data. But what I find interesting is that the Telstra smart router 3 seems to allow it to play nicely so something is going on here with the ISP router vs Orbi. In any case, the orbi is now just an expensive wifi without using the other great features.
- michaelkenwardDec 09, 2022Guru - Experienced User
Is the Telstra thing sitting in front of the Orbi?
Are they running them in serial (one after the other)?
If so you should investigate how they work together.
If the Telstra "smart router 3" really is a router, then as FURRYe38 suggests, you may run into this problem:
What is Double NAT? | Answer | NETGEAR Support
Your system should be able to accommodate that during the setupstage, but there's no guarantee there.
I didn't pick up on your earlier comment:
I have tried to put a managed switch to reduce the egress to fit the 22mg profile with the switch between the NTD and Orbi but it still does not work.
I don't understand most of that, or why you went down that road, but I fear that you are making life hard for yourself. Don't follow up ever daft idea you find on Google and get back to basics.
My guess is that your Teams issues are down to something else that is amiss in your setup.
- RnubesDec 09, 2022Aspirant
When the problem occurred, I removed the orbi and used the ISP Telstra supplied router and it worked. The only way I can use them both is to use the Telstra modem with the orbi in AP mode. that sorted the teams problem out. Interesting is that this problem also occurred when I used Optus nbn. I do agree teams is the problem, but what I cannot work out is why swapping the orbi for the ISP router fixed it. It seems the ISP router somehow caters for this teams mess when both were configured the same.
I did read that the NBN do 'police' excessive uploads by dropping upload traffic in excess of your plan. it is a terrible service where you pay for 250mb download speed but only get 22mb upload speed, i am sure if they allowed faster upload teams would work as it worked when I was in the US on a fast upload.
I will stick to the orbi being in AP mode for now connected to the ISP router. Maybe teams will be fixed one day but I doubt it.
- michaelkenwardDec 10, 2022Guru - Experienced User
I do not suggest that Teams is the problem so much now that we know that you are throwing two routers into the fray. That wasn't in your first message.
Now we know that you might be another victim of "double NAT".
What might be the issue is how the Teams client and the browser work with they encounter the double-NAT
It seems the ISP router somehow caters for this teams mess when both were configured the same.Again, that is not the conclusion I would take from this. That you can get it to work with the Orbi in AP mode suggests that the setup on your network in the cause rather than the behaviour of individual devices.
A more conventional way to deal with this sort of problem is to see if you can put your modem/router into bridge (modem only) mode.
But that depends on what features you want the Orbi to manage.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I can't see how the upload traffic would differ much between the Teams client and the browser version. Again, if you want to take that up with your ISP, you should provide more evidence or they may just put it down to a badly configured network at your end.
When I encounter problems, I usually start with the simplest explanation (the network setup) rather than jump to conclusions about wicked ISPs (and NBN), buggy cloud services (Teams) or crummy hardware (Orbi).
