Rnubes
Dec 09, 2022Aspirant
Orbi on NBN FTTP MS Teams Video not work
hi, I have Telstra NBN FTTP at 250/22Mg speed with Orib RBK50. For some reason, MS Teams on windows 11 using the native MS Teams client does not do video very well, it just does not work. I can see ...
michaelkenward
Dec 10, 2022Guru - Experienced User
Rnubes wrote:
I do agree teams is the problem, but what I cannot work out is why swapping the orbi for the ISP router fixed it.
I do not suggest that Teams is the problem so much now that we know that you are throwing two routers into the fray. That wasn't in your first message.
Now we know that you might be another victim of "double NAT".
What might be the issue is how the Teams client and the browser work with they encounter the double-NAT
It seems the ISP router somehow caters for this teams mess when both were configured the same.
Again, that is not the conclusion I would take from this. That you can get it to work with the Orbi in AP mode suggests that the setup on your network in the cause rather than the behaviour of individual devices.
Rnubes wrote:
The only way I can use them both is to use the Telstra modem with the orbi in AP mode. that sorted the teams problem out.
A more conventional way to deal with this sort of problem is to see if you can put your modem/router into bridge (modem only) mode.
But that depends on what features you want the Orbi to manage.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I did read that the NBN do 'police' excessive uploads by dropping upload traffic in excess of your plan. it is a terrible service where you pay for 250mb download speed but only get 22mb upload speed, i am sure if they allowed faster upload teams would work as it worked when I was in the US on a fast upload.
I can't see how the upload traffic would differ much between the Teams client and the browser version. Again, if you want to take that up with your ISP, you should provide more evidence or they may just put it down to a badly configured network at your end.
When I encounter problems, I usually start with the simplest explanation (the network setup) rather than jump to conclusions about wicked ISPs (and NBN), buggy cloud services (Teams) or crummy hardware (Orbi).
Rnubes
Dec 11, 2022Aspirant
thanks for the replies.
I am not using two routers to result in double NAT, if I do use two, I use the ISP router with the Orbi in AP mode (ISP wifi disabled).
The network is configured the same when using Orbi vs ISP router and does not have any complications.
Teams client vs browser traffic I am not sure what is going on here so any experts on team may be able to provide info, the client does have more functionality so assuming it does more caching etc.
It may be a 'simple' fix, but a quick search of other forums indicates this is an extensive issue with many users, who typically solve it using the ISP router or with a non ISP router by shaping the egress traffic.
I am resigned to the fact it is not easily solved and will use the ISP router with the Orbi in AP mode with limits on parental controls which is something I wanted to use.
