AlexStormez
Aug 27, 2020Aspirant
Orbi only goes up to 300mbps hardwired
Had Orbi Rbk53 , V2.5.1.16 almost a year, no issues at all Recently ugraded my broadband profile from 300/50 to 1000/100 and for some reason i only could reach 290 mbps download ( same as befor...
- Aug 27, 2020
what does it show when you use the app or orbilogin.com speed test, as it is going to give you the connection speed to the internet from the Orbi router?
Do you have a switch or anything in between the Orbi router and ISP modem?
Have you recently updated the firmware, as there have been repeated reports of slower speeds.
Mstrbig
Aug 27, 2020Master
AlexStormez
Thank you guys , it is fine now.
It is hard to know why and what was the cause of it.
It was 280 mbps through the Orbi web UI ( internal speed test tool).
I've tried Orbi Android App then and run speed test tool trough this APP , and Finally got 915/97 !!!
It is running at the full capacity now ( Orbi web UI speed test showing 900 as well )
I guess it might be something to do with dynamic QoS which is hidden from the user and it takes some time before updates the QoS profile...
