Loonan4
Jun 03, 2021Follower
Orbi only working intermittently
Router is only working intermittently. Good signal to house but signal keeps dropping from router.
michaelkenward
Jun 04, 2021Guru - Experienced User
Too, little information. (What is intermittently?) Probably the wrong place to ask.
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but Orbi devices are not bog standard routers, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
