SleeplessInPDX
Feb 02, 2020Aspirant
ORBI OpenVPN not working with Windows 10 client
I have setup my Orbi for OpenVPN and followed the instructions closely on both the Orbi router side and client side. For Android and iOS devices, Orbi's OpenVPN is working such that a VPN session is...
- May 22, 2020I worked with Netgear tech support a few weeks ago on this. The problem is solved. Apparently, the configuration file was bad on the particular revision of Orbi firmware I was using. I had updated the firmware but not the configuration file. Tech support suggested replacing the Open VPN configuration file. When I did that it started working.
