Surffa's avatar
Surffa
Apprentice
Jan 11, 2021
Orbi OpenVPN server leaks IPv6
Hi folks.
Again a bit more special topic from my side. I've been struggling with the OpenVPN setup of Orbi for quite some time and now finally got fed up with the IPv6 traffic leaking, which makes me temporarily disable IPv6 on the client side as I've been unable to figure out another way around the problem.
Anyway. Server side problem description and solution is explained fairly well here:
https://www.sindastra.de/p/807/quickly-kill-ipv6-leaks-on-your-openvpn-server/
Now. I'm not sure if there is any free of charge way to sugges this configuration change to Netgear, if there is, feel free to instruct how to do it?
Otherwise I'm also open for any other workaround suggestions than disabling IPv6 completely on the client side?
Anyway, as IPv6 is actually very common nowadays, this is really a pain.
Thanks.
  • CrimpOn's avatar
    CrimpOn
    What about BugBounty?
    https://bugcrowd.com/netgear
    Or, send a private message to one of the forum moderators, who could forward it to Netgear engineering?
    Although this may be "obvious", I am confused about which client addresses are being leaked.
    OpenVPN on the Orbi is a "server", so the clients are computers that tunnel through the VPN to reach the Orbi.
    How does anything about such devices reach the internet?
    • Surffa's avatar
      Surffa
      Apprentice
      Thanks for your reply. Let's see if I could work from there.
      Anyway, yes, I was also puzzled how that leaking happens. It's not exactly what I expected. But it appears that the at least in this specific case Orbi that I use is connected to network where there is no IPv6 available, although I'm not sure if Orbi woul utilize IPv6 for OpenVPN anyway. Client then is in IPv4/v6 dual stack network and Orbi server config is configured to take all the client traffic.
      How the problem is then visible, is easy. All the connections to hosts that do have an IPv6 address get contacted through IPv6 directly and not through the OpenVPN tunnel that would be obviously IPv4 only connection. I haven't studied if this affects servers that are IPv6 only or if it's enough that an AAAA entry exists for a domain name in parallel. One can reproduce this by accessing one of those "What's my IP address"-sites that is IPv6 capable or like in my case some IPv6 video streaming site that applies stricts regional restrictions.
      • Surffa's avatar
        Surffa
        Apprentice
        Btw. For the completeness, it appears to happen with Win10 client, but right now it seems that Android is not affected. Anyway, problematic enough either way.
