pack09's avatar
pack09
Orbi or iOS 14 blocking websites/apps
Since setting up my mesh Orbi (RBR750) system I have noticed websites and apps on my phone (iPhone 12 with iOS 14) will not load, “server not found” & “try connecting again” errors are occurring. I did the 443 and 80 ports, but still not getting consistent performance. I have firmware V3.2.18.1 and I have also utilized openDNS as well to try and help. I have tried turning Armor on and off. Is there something I am missing. Windows 10 computer on explorer seems fine, Roku TV seems fine. iPhone IS NOT lol. Help please.
  • > [...] iOS 14 [...]
       The usual recent iOS complaint is this:
          https://support.apple.com/en-us/HT211227
    but that affects whole wireless connections, not selected traffic.
    > [...] I did the 443 and 80 ports, [...]
       I don't know what that means, but it sounds misguided.
    • pack09's avatar
      pack09
      Thanks for the provided link, I have read similar threads. Tried both private and not. Seems to be indifferent.
      As for the ports: 443 is to allow HTTPS and 80 is for HTTP. I have read several complaints that porting both helps.
      This morning I have reset my modem (personally owned Arris S33 D3.1) through my ISP, and rebooted my router after applying WPA3 security. That did not change anything except remove my IoT that cannot connect that way, so that’s not an option either.
      • antinode's avatar
        antinode
        Guru
        > [...] Tried both private and not. Seems to be indifferent.
           As I wrote, it didn't seem to apply.
           I know how these ports are used.  What you did with them is (still) a
        mystery.  If you're talking about port forwarding, then that is relevant
        for _incoming_ connections to a (web) server; it's irrelevant for using
        a web browser.  What, exactly, does "porting" a port or "doing" a port
        mean to you?  I also don't know what you might have read.
        > [...] Arris S33 [...]
           That's a modem; it should be transparent.
           Does this iPhone work as expected when connected to some other
        router?  Do other wireless devices work (with the same web sites/pages)
        that cause problems with this iPhone?
           "server not found" sounds like DNS, but I know nothing about your DNS
        configuration(s).
    The suggested solution is to reset the Orbi system and not turn Armor on, but this is not a satisfactory solution in my view, as I purchased a  paid subscription to Armor for the protection it claims to provide.
    My Orbi System is an RBR50 router, with two RBS50 satelites connected. Firmware is the latest version V 2.5.1.16.
    • Dydefox's avatar
      Dydefox
      Same here, still blocking issues.
      The suggested solution: reset everything en reinstall router and satellites resulted in a further problem: not able to download firmware. Skipped that, but the problem remains: blocked apps are banking, google (including google search!) and other apps that use some blocking data.
      I have tried altering DNS, IP and other methods, but still I have to switch to cellular to check my Gmail, bankaccount and webcams.
      All other devices and apps are working fine, iPhones and iPads excluded.
      WHY O WHY is this not easy to solve? Please let me know...getting desperate.
      • FURRYe38's avatar
