jkimbro
Dec 09, 2019Tutor
Orbi or mesh question(s)
Hey all,,, I've got an older DGND4000 and a couple other routers I use just use as "extenders",, but I think it's time to upgrade and I'm thinking maybe to a mesh system. Currently I have DSL,,, ya,...
Dec 10, 2019Guru - Experienced User
You might try to bridge the modem as well if it supports this feature. Then you can run Orbi in router mode.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jkimbro wrote:Hey all,,, I've got an older DGND4000 and a couple other routers I use just use as "extenders",, but I think it's time to upgrade and I'm thinking maybe to a mesh system. Currently I have DSL,,, ya,, I know but it's all we can get out here besides satellite.
Anyway, I'm looking at the Orbi,, probably the one before the 6.
Opinions? And I would need to get a DSL modem,,, correct? Anything else?
Thanks
