LSweet's avatar
LSweet
Orbi or Nighthawk A7000 Massive Ping Spikes
This has started to get much worse recently but for a long I would experience lag spikes that would last about 3 seconds. These lag spikes would happen about every 20-30 seconds. I would ping google ...
  • FURRYe38's avatar
    If pings are good when closer with the PC wirelessly and good with wired directly to the RBR, then I would presume your adapter maybe the cause if what your seeing.
