tel851
Sep 08, 2021Tutor
Orbi or Powerline
I live in a two-bedroom unit that is approximately 108m2 or 1160sq ft. My AVM Fritzbox 7590 modem is located in a closet with the NBN box (National Broadband Network). Occasionally my WIFI signal...
- Sep 10, 2021
Thanks plemans.
Sep 09, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Occasionally my WIFI signal is weak in the bedroom so I was looking at getting a Netgear Orbi or a Netgear Powerline to boost the WIFI signal in the areas of the unit where the signal is weakest.
Do I get an Orbi router to connect into my current modem and an Orbi Satellite to place somewhere else in the unit, or do I get an Orbi Satellite only and sync it with my current modem?
On the other hand, do I get a Netgear Powerline and connect it with my Netgear Hub as my TV, Apple TV and PVR are connected to the HUB via RJ-45 cables?
Any ideas please?
tel851
Sep 09, 2021Tutor
I have attached a couple of photos to show you where my modem is located, which is in a cupboard, next to my kitchen. I don't think I can move my modem to a better location as there are three RJ-45 cables connected to the modem which connect to my study room and lounge room via a network of wall sockets.
In the lounge room I have a Netgear Hub which has RJ-45 cables connected to my TV, Apple TV and PVR
- plemansSep 10, 2021Guru - Experienced User
with your setup and each room being wired, you could centrally locate an access point.
You could use a router, an extender with access point mode, or even an access point.
having everything hardwired gives you lots of options.
- tel851Sep 10, 2021Tutor
Thanks plemans.
