tel851
Sep 08, 2021Tutor
Orbi or Powerline
I live in a two-bedroom unit that is approximately 108m2 or 1160sq ft. My AVM Fritzbox 7590 modem is located in a closet with the NBN box (National Broadband Network). Occasionally my WIFI signal...
- Sep 10, 2021
Thanks plemans.
tel851
Sep 09, 2021Tutor
I have attached a couple of photos to show you where my modem is located, which is in a cupboard, next to my kitchen. I don't think I can move my modem to a better location as there are three RJ-45 cables connected to the modem which connect to my study room and lounge room via a network of wall sockets.
In the lounge room I have a Netgear Hub which has RJ-45 cables connected to my TV, Apple TV and PVR
Sep 10, 2021Guru - Experienced User
with your setup and each room being wired, you could centrally locate an access point.
You could use a router, an extender with access point mode, or even an access point.
having everything hardwired gives you lots of options.
- tel851Sep 10, 2021Tutor
Thanks plemans.
