9768malcolm
Oct 04, 2019Follower
Orbi Outdoor and cable modem compatibility
Does anyone know if the Netgear Orbi Outdoor wifi range extender/booster is compatible with my Netgear CG3000-2STAUS cable modem supplied by Optus? I have a seperate dwelling about 18 meters from th...
CrimpOn
Oct 04, 2019Guru - Experienced User
Yes, the RBS50Y can be connected to a "non-Orbi" WiFi system. See the installation guide here:
http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
This satellite is clearly intended to be part of an Orbi system, but Netgear has no other outdoor rated WiFi units. So, the RBS50Y has a switch so it can be "Orbi" or "non-Orbi".
