MrToadsWildRide
Dec 04, 2019Guide
Orbi outdoor RBS50Y leaks..ruined by water
I noticed my backyard devices were not connected any longer to the internet today after our first rain in 9 months yesterday. Immagine my surprise when I took off my Orbi outdoor satellite RBS50Y sp...
mgil1
Jun 14, 2020Star
Exact same problem - fitted two of these outside about a year ago - when removing one to use elsewhere I discovered it had water inside the casing - still washing around and explains why signal was always so bad from this one - absolute disgrace in design for this to happen - other one is working fine and seems still to be dry
mgil1
Jun 15, 2020Star
So having had this problem I spent last evening stripping down the unit - since it was pretty much dead from about an inch of water that had caused various damage to the circuit board - photo attached - I dried the inside of the unit and components - sprayed the circuit board with IPA (Isopropylalcohol) and left it to soak and clean off for about 4 hours - I was able to kick the unit back into life - I've reassembled and will reuse outdoor only where it has a cover over the top (ie under eaves of a roof like the other one I have which was not damaged) - stripping the unit down shows this is not water proof - the seal top and bottom look more 'weather proof' - where I had these units in Scotland they could not deal with the sustained rain downfall we tend to get up here-anyway its back working - word to the wise if you are in a reallly wet area put it under some sort of cover - just to stop direct downfalls of rain onto the slanted top part of unit!
