MrToadsWildRide
Dec 04, 2019Guide
Orbi outdoor RBS50Y leaks..ruined by water
I noticed my backyard devices were not connected any longer to the internet today after our first rain in 9 months yesterday. Immagine my surprise when I took off my Orbi outdoor satellite RBS50Y sp...
urkase3
Dec 16, 2020Aspirant
Honestly it looks as if my Iphone X will not connect to the satellite tv for pc. I suppose once I'm ~50ft from my residence it connects with reviews to fundamental router, then when i flow similarly away it drops from major router and doesent pick up the nearby satellite?
- huff240Jan 09, 2021Initiate
I really sad for this behavious of seller or manufacturer who ignore to replace it. Its responsibility of company why water proof thing contains water in it? What the hell it is? it is game of water ball? Secondly as you mentioned first time rain comes and it happened. We can consider it even too much rains and it is flooded with water due to that. Shameful act of those companies and seller.
- alokeprasadJan 09, 2021Mentor
One year of warranty use would expose them to some rain and temperature changes. All seals deteriorate with time, temperature and moisture, unfortunately, but not that soon.
I don't have this device. A well-sealed device with rubber gaskets should take a soaking and last many years, you'd think ...
When I buy an outdoor device (I have a couple of Ring battery operated cameras), I hose them down a few times with my garden hose to check their seals. Well within the warranty period, of course.
