MrToadsWildRide
Dec 05, 2019Guide
Orbi outdoor RBS50Y leaks..ruined by water
I noticed my backyard devices were not connected any longer to the internet today after our first rain in 9 months yesterday. Immagine my surprise when I took off my Orbi outdoor satellite RBS50Y sp...
mgil1
Sep 25, 2020Star
See my earlier post....I had exact same poroblem but soaked the circuit board in IPA (Iso proply Alcohol) left oit to dry for 4 hours and it miraculously came back to life after a reboot - if this works and you want to continue to use it outside wrap some electric tape around the seals to prevent reoccurence
hope it helps good luck
Mstrbig
Jan 09, 2021Master
mgil1 wrote:See my earlier post....I had exact same poroblem but soaked the circuit board in IPA (Iso proply Alcohol) left oit to dry for 4 hours and it miraculously came back to life after a reboot - if this works and you want to continue to use it outside wrap some electric tape around the seals to prevent reoccurence
We stopped using the RBS50Y because they don't hold up in Florida. We now use an RBS50, (or any satellite), with a 3rd party weatherproof box. We've had great luck, in the past before mesh systems, installing outside routers around motels, etc for years. So we decided to apply this application for a yard satellite, after many RBS50Y failures.
- CrimpOnJan 09, 2021Guru - Experienced User
(Thanks for the hint that Amazon carries a wide variety of weatherproof enclosures.) Can you please expand on how Orbi satellites handle the heat when hermetically sealed in one of these?
- sterlingaJan 09, 2021Initiate
I recall your first posting about success with alcohol. Actually, I have used that togrther with sun-baking on cellphones I have taken swimming. I tried with my Orbi but my damage was either more extensive or just too much time had elapsed but it didn't help.
I am interested in the weatherproof box idea, since the other units work fine. Can you share a specific product id that fits the Orbi?
(Still very disappointed with NetGear for ignoring all these stories. Maybe it's time to share this with Top Class Actions or Class Action.org)
- MstrbigJan 09, 2021Master
There are many boxes to choose from on Amazon and other places. They are many different prices as well. Just make sure you choose on that fits the satellite you are using. This one is fairly inexpensive.
This one a little nicer:
This is more nicer:
Heat here in Florida doesn't seem to cause any issues. Most boxes have some sort of ventilation, but still keeps the rain water out.
And we get some bad rainstorms here.
