MrToadsWildRide's avatar
Dec 04, 2019
Orbi outdoor RBS50Y leaks..ruined by water
I noticed my backyard devices were not connected any longer to the internet today after our first rain in 9 months yesterday.  Immagine my surprise when I took off my Orbi outdoor satellite RBS50Y specifically designed to be outdoors and waterproof and found it full of water and water fooded out when it was turned over.  I have only had it a little over a year.
I called customer and technical support and was told it could not possibly be leaking and it was out of warranty.  See for  yourself and be warned.  Anyone else have this problem and just lost over $300 to deceptive advertising?
  • Yes.  Same problem here.  I am pretty upset and bummed.  I had the device attached to my back deck so we would have reliable wifi service on the back patio.  Then, I noticed that it wasn't working...It was disconnected from the network maps and just wouldn't connect. After trying everything I could think of in the app, I decided to take it down.  To my surprise, the OUTDOOR satellite was filled with water!  I couldn't figure out how water got in it. There are no visible cracks or spaces on the device. Also, I have had it sitting for months inside, hoping the water would somehow evapourate, so I could get it to work again.  No such luck, the water is still in it.  What's most disappointing to me was that when it first happened, I couldn't even figure out how to get a hold of a live person at Netgear support for help.  I was really mad, so I just gave up.  Just calmed down enough to try again.  Up until now, I only bought netgear products.  Very, very, very, disappointed. Talk about deceptive advertising.
    • CrimpOn's avatar
      CrimpOn
      Since it is dead, you have nothing to lose by taking it apart to get the water out.
      The FCC filing gives me the impression that removing the screws on the  back may allow the case to be pried open.
      From the picture, some look like Philips head and some like Torx.
      https://fccid.io/PY317200377/Test-Report/RF-Test-Report-BLE-3662484
      Page 5 seems to indicate that the top and bottom can come off.
      • McBarch's avatar
        McBarch
        Initiate
        The top and bottom do come off with a little effort.  We opened it up, let it dry out, and reinstalled the top and bottom covers with some added silicon sealer (from a store like Home Depot) so that it would flex with it.  I have also been keeping it upside down for now so that if any water were to get in, it would sit in the open space at the top as opposed to submerging the electronics at the bottom. So far we have not gotten any new water in it in at least a year now. It has been working good so far!
