gregbart76
Feb 12, 2021Follower
Orbi outdoor satellite amber flashing light
The light flashes orange on and off, it is extremely cold 25 degrees so not sure if that is part of the reason. It stills works but thiis is my second unit, the first one started doing this then failed altogether.
1 Reply
- vajimMaster
gregbart76 wrote:The light flashes orange on and off, it is extremely cold 25 degrees so not sure if that is part of the reason. It stills works but thiis is my second unit, the first one started doing this then failed altogether.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
