Doug6392
Jul 04, 2021Guide
Orbi outdoor satellite is making clicking noises
The satellite is mounted on an outside wall, under an overhang, and has started making a fairly constant clicking noise. It appears from the app to be operating normally, but the noise is distracting....
CrimpOn
Jul 04, 2021Guru - Experienced User
Doug6392 wrote:
The satellite is mounted on an outside wall, under an overhang, and has started making a fairly constant clicking noise. It appears from the app to be operating normally, but the noise is distracting. Neither the router nor the other 2 indoor satellites make any kind of noise while operating. Any suggestions?
If it is less than 1 year old, I would contact Netgear about a warrenty replacement.
There have been a number of reports of users finding water inside their RBS50Y's. If you shake it, does it "slosh"?
- Doug6392Jul 05, 2021GuidePurchased 3 years ago, I think, so no dice. Haven't checked for water, but the last time I had it down for system maintenance it was dry. (North wall, so little rain exposure, and only a foot or 2 below the soffit, which protrudes 2-3 feet. Pretty hard for rain to get to it.)
- FURRYe38Jul 06, 2021Guru - Experienced User
So what happens if you turn OFF the RBSY? Does the clicking noise still being heard? Can you take the RBSY into the home where is quite and plug it in there and observe the noise?
- Doug6392Jul 06, 2021GuideSensible troubleshooting steps, for sure. Since it's mounted on a wall about 8' off the ground with security screws, and it's supposed to be near 30°C (without factoring in humidity) I may wait for a cooler day to take it down and try those things. Much appreciate the reply. (BTW, I love in the country at the end of a dead-end road, so it's pretty quiet even outdoors. That's why my wife heard the clicking while we were sitting in our gazebo. :) )
