till18
Nov 25, 2018Follower
Orbi Outdoor Satellite RBS50Y losing connection to Router
Since beginning of the year I'm successfully running a SRR60 Router with two SRS60 Indoor Satellites. I bought them in Switzerland (where I live). As the connection in our garden wasn't satisfying I ...
mgil1
Feb 09, 2019Star
Re Outdoor Orbi satellite RBS50Y-I've just installed into a newtork thats been stable for over a year with wired Orbi Satellites and wi-fi connected ones - I'm having exactly the same problem - the satellite is stable and then after a few hours starts going orange to blue then ultimately Magenta...2 questions
does anyone have a fix
is it possible to hardwire via ethernet backhaul to another satellite?
Feb 09, 2019Guru - Experienced User
FW up to date?
Factory reset and setup from scratch?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
The satellite can be wired to the router.
