rphnj's avatar
rphnj
Follower
Jun 11, 2018
Orbi Outdoor Satellite RBS50Y
Is the Orbi Orbi Outdoor Satellite ok to install in a high humidity environment (indoor pool area)?
  • FURRYe38's avatar
    I would check the specs to see if there is anything listed. If it's out door, usually means it can handle some form of humidity.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Operating temperature 4°F to 122°F (–20°C to +50°C)
    Operating humidity 90% maximum relative humidity, noncondensing
