d4dr0ck's avatar
d4dr0ck
Tutor
Mar 21, 2019
Orbi Outdoor Satellite Used to Work, Now Does Not
Greetings friends - any helpful ideas would be most welcome.  Details below, but in short, I'm trying to get an Outdoor Satellite to reliably work.   The setup in the house is cable modem to the ...
  • Chuck_M's avatar
    Chuck_M
    Mar 21, 2019
    Ok, the first thing I would do would be to manually update to most current firmware.  You have a mish-mash of older versions which have known backhaul issues.
    Do the satellites first.  RBS50s should be updated to version .32.
    Regarding your router...  you will have to update that to an intermediate version before going to the final version which is .32.  The reason is because the newest firmware image is larger than the RBR50 used to allow.  The intermediate version changes that parameter and allows you to load the final (larger version).
    Here is the RBR50 Intermediate Firmware link:
    https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
    Here is the RBR Objective/final Firmware link (V.32)
    http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.0.32.zip
    Your "Y" is at the most current version so leave that alone.
    Your  RBW30 should be updated to 2.3.0.4.  Here is the update link
    http://www.downloads.netgear.com/files/GDC/RBW30/RBW30-V2.3.0.4_1.0.5.zip
    You can always bookmark the Netgear Download Center: https://www.netgear.com/support/download/ forfirmware versions.
    After completing your firmware updates of satellites and then router... I recommend doing a factory reset to clear out any odd settings or whatnot that might have followed you
    Then setup your router and make the SSID and password what it was before so all your devices join without having to reconfigure.
    I think at the end of the day some of your stuff was running pretty outdated firmware so this should help at least with stability and backhaul.
    I also think that when you reset it rejoins 2.4 and 5g.
    You have already configured your IOT devices so they should fall right back in where they belong as long as you use the exact same SSID and password as before.
    WIFI analyzer is indeed a phone app.  You might want to load one and check out if anyone is stepping on your channels you are using
    Message me or post on here if you have any questions.
