fade6
May 09, 2020Aspirant
Orbi Outdoor Time Different
Hello. I have a schedule set for the outdoor LED to turn on/off. However I've figured out that the outdoor is 4 hours off from the actual time. I've verified that the router time is accurate. So, for...
May 11, 2020Guru - Experienced User
Are you referring to RBS50Y?
fade6
May 11, 2020Aspirant
Yes, exactly - sorry should have included that
- FURRYe38May 11, 2020Guru - Experienced User
So if you factory reset the RBSy while in the same room as the RBR, the time seen on the RBSY is off?
Something to contact NG support about:
https://www.netgear.com/support/#
I know the RBSY FW is not at the same version level as most current FW for the RBR/RBS. So something maybe out of sync in RBSY FW.
- Blanca_OMay 18, 2020NETGEAR Employee Retired
Hi fade6
How did you setup the Orbi Outdoor satellite? Is in Extender mode or Orbi mode?
What is the firmware version?
Brand and model of the router? If NETGEAR, what is the firmware version?FURRYe38, thanks for looping me in!
Looking forward to your response.
Blanca
Community Team
