bager33S
Jul 31, 2017Aspirant
Orbi pairing issue
When setting up the Orbi, I never got the LED Blue ring on the router. I did have it on the satellite. The signal from the satellite is stronger than the router. Does this mean that the pairing is no...
bager33S
Thanks for the lead justSomeone.
DarrenM
Aug 02, 2017Sr. NETGEAR Moderator
Hello bager33s
Make sure that both devices are on the 1.12.0.18 firmware version and then it should just depend where you are in your house whether your devices will connect to the satellited or the main router.
DarrenM
