Netwizard17
Jul 08, 2017Follower
Orbi Parental Controls (Device Schedules)
Does Netgear plan to implement Parental Controls on the Orbi like some of their competitors where you can set schedules to specific devices that disables the internet at specified times?
DarrenM
Dec 14, 2017Sr. NETGEAR Moderator
Hello seanyoung
if you want control of each specific device you will have to download the 2.1 orbi firmware and load it onto your system and use the Disney circle parental controls.
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/td-p/1447612
DarrenM
Jeffrey0707
May 22, 2018Guide
The Orbi is one of the most expensive routers on the market, albeit with high-end functionality. Unfortunately, however, with the introduction of the firmware v 2.1.1.12, parental controls beyond basic filtering cost an additional $4.99 per month via Disney Circle Even as I write this, I cannot believe that Netgear is expecting its customers to pay for functionality that other manufacturers include as standard.
