Folbo
Oct 20, 2018Guide
Orbi performance ... well there is none ... how do I fix it?
I wanted mesh and was told by the interweb that Orbi was the best ...
My network is an ethernet connection from the modem by the front door up to a bedroom at the rear of the house on the firs...
Oct 21, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
My network is an ethernet connection from the modem by the front door up to a bedroom at the rear of the house on the first floor. It then communicates to a cabin at the end of the garden via wifi. A natural daisy chain.
I was using an Apple TC (with ac wifi) in the bedroom, and another Apple ac TC in the cabin. They communicated well. Reasonably fast and very reliable. I wanted to replace this with a mesh network, with the router by the front door, and two satellites being direct replacements for the aging Apple devices. They are in the same place, with the same cabling, and same blocking walls/distance... and the Orbi cannot even keep a reliable connection, let alone come close to the Apple time capsules. Given that all other things are equal, why does the Orbi hardwarenot manage to do what Apple was doing some years ago? And more importantly, how can i fix it?
All three devices are running the latest and same firmware.
The iPad app verges on the pointless ... and connecting directly to the orbio router via a browser gives so few functional choices that I am stumped.
Thanks.
