CMYK
Apr 21, 2018Tutor
Orbi Periodic Slow Wired Connection to Satellite
I have a PC (1 GB ethernet) connected by Cat5 cable to a RBS50 satellite. Periodically (every couple weeks), the download speeds drop from 70 Mbps (this is max - it's what we pay Comcast for) to 3 Mb...
Apr 21, 2018Guru - Experienced User
Do other wired devices see similar issue if you have a spare PC or laptop to test with?
What is the Mfr and model of this PC?
What is the Mfr and model# of the ethernet adapter card in the PC?
What FW are you using one the router and satellite?
CMYK
Apr 21, 2018Tutor
Firmware is 2.1.3.4 for both router and satellite.
PC was self-built a couple years ago (i7-5820K); the motherboard is MSI X99A SLI PLUS ATX LGA2011-3.
This wasn't an issue with the EX7000 that the Orbi replaced, so I don't think it's a hardware issue with the PC.
I do not have another laptop to test wired connection speed (no ethernet ports on our laptops), but I will try to figure something else out.
