CMYK
Apr 21, 2018Tutor
Orbi Periodic Slow Wired Connection to Satellite
I have a PC (1 GB ethernet) connected by Cat5 cable to a RBS50 satellite. Periodically (every couple weeks), the download speeds drop from 70 Mbps (this is max - it's what we pay Comcast for) to 3 Mb...
Apr 21, 2018Guru - Experienced User
Ok.
Just curious, what is the Mfr and model of the ethernet card in this PC?
- CMYKApr 21, 2018Tutor
Ethernet is in the motherboard (model number above). The chipset uses an Intel I218 Gigabit LAN.
- FURRYe38Apr 22, 2018Guru - Experienced User
Yes, was looking for the chip set Mfr of the ethernet adapter on the motherboard.
Thanks
- Mayhugh1Apr 22, 2018Apprentice
I have exactly this problem with one of my satellites and my ipad pro. I'm using the ....18 software. I was hoping this was fixed in the new beta, but I guess it wasn't
