CMYK
Apr 21, 2018Tutor
Orbi Periodic Slow Wired Connection to Satellite
I have a PC (1 GB ethernet) connected by Cat5 cable to a RBS50 satellite. Periodically (every couple weeks), the download speeds drop from 70 Mbps (this is max - it's what we pay Comcast for) to 3 Mb...
Apr 21, 2018Guru - Experienced User
Ok.
Just curious, what is the Mfr and model of the ethernet card in this PC?
CMYK
Apr 21, 2018Tutor
Ethernet is in the motherboard (model number above). The chipset uses an Intel I218 Gigabit LAN.
- FURRYe38Apr 22, 2018Guru - Experienced User
Yes, was looking for the chip set Mfr of the ethernet adapter on the motherboard.
Thanks
- Mayhugh1Apr 22, 2018Apprentice
I have exactly this problem with one of my satellites and my ipad pro. I'm using the ....18 software. I was hoping this was fixed in the new beta, but I guess it wasn't
Do other devices work ok with your satellite?
Was a full factory reset and set up from scratch performend on the router and satellite after updating to v2.1.3.4 FW?
Mayhugh1 wrote:I have exactly this problem with one of my satellites and my ipad pro. I'm using the ....18 software. I was hoping this was fixed in the new beta, but I guess it wasn't
