machrider
Sep 07, 2020Initiate
Orbi ping is awful
I have a new RBK853 system and my latency when pinging the router is just terrible. I see the same thing on multiple devices. 3-4ms pings with 80-120ms pings sprinkled in every couple seconds. I ...
machrider
I just tried connecting to a satellite and pinging it, it's even worse than the router.
PING 10.0.0.8 (10.0.0.8) 56(84) bytes of data. 64 bytes from 10.0.0.8: icmp_seq=1 ttl=64 time=5.76 ms 64 bytes from 10.0.0.8: icmp_seq=2 ttl=64 time=6.85 ms 64 bytes from 10.0.0.8: icmp_seq=3 ttl=64 time=5.96 ms 64 bytes from 10.0.0.8: icmp_seq=4 ttl=64 time=8.17 ms 64 bytes from 10.0.0.8: icmp_seq=5 ttl=64 time=67.9 ms 64 bytes from 10.0.0.8: icmp_seq=6 ttl=64 time=7.79 ms From 10.0.0.7 icmp_seq=7 Destination Host Unreachable From 10.0.0.7 icmp_seq=8 Destination Host Unreachable From 10.0.0.7 icmp_seq=9 Destination Host Unreachable From 10.0.0.7 icmp_seq=11 Destination Host Unreachable From 10.0.0.7 icmp_seq=12 Destination Host Unreachable From 10.0.0.7 icmp_seq=13 Destination Host Unreachable From 10.0.0.7 icmp_seq=14 Destination Host Unreachable From 10.0.0.7 icmp_seq=15 Destination Host Unreachable From 10.0.0.7 icmp_seq=16 Destination Host Unreachable 64 bytes from 10.0.0.8: icmp_seq=17 ttl=64 time=2087 ms 64 bytes from 10.0.0.8: icmp_seq=18 ttl=64 time=1064 ms 64 bytes from 10.0.0.8: icmp_seq=19 ttl=64 time=35.6 ms 64 bytes from 10.0.0.8: icmp_seq=20 ttl=64 time=2.59 ms 64 bytes from 10.0.0.8: icmp_seq=21 ttl=64 time=62.9 ms 64 bytes from 10.0.0.8: icmp_seq=22 ttl=64 time=3.18 ms 64 bytes from 10.0.0.8: icmp_seq=23 ttl=64 time=2.61 ms 64 bytes from 10.0.0.8: icmp_seq=24 ttl=64 time=22.9 ms 64 bytes from 10.0.0.8: icmp_seq=25 ttl=64 time=3.45 ms 64 bytes from 10.0.0.8: icmp_seq=26 ttl=64 time=0.676 ms 64 bytes from 10.0.0.8: icmp_seq=27 ttl=64 time=127 ms 64 bytes from 10.0.0.8: icmp_seq=28 ttl=64 time=72.8 ms 64 bytes from 10.0.0.8: icmp_seq=29 ttl=64 time=10.7 ms 64 bytes from 10.0.0.8: icmp_seq=30 ttl=64 time=3.46 ms 64 bytes from 10.0.0.8: icmp_seq=31 ttl=64 time=16.7 ms 64 bytes from 10.0.0.8: icmp_seq=32 ttl=64 time=126 ms
Coming from an ancient Linksys router that would consistently give 1ms pings, this $1000 mesh system is a huge disappointment.
Mstrbig
Sep 07, 2020Master
Reasons why you may have bad pings:
Hardware issues, cable issues, WIFI interference, ISP issues
Internet connection speed
Firewalls, especially if more than one used (example 3rd party and Windows built in)
Distance between satellite and server
